I just plugged in my 02 simulator in the RS and I cranked it up and the ses light was still there. Drove it around for a little while and it didn't go away. And what are you suppose to do with the chord coming from the exhaust pipe....do I take that off? Not sure why its not working, the simulator is on the part after where the cat use to be.
02 simulator problem
yea i hear you. when i got my exhaust done they put the simulators in and the light was still there. so i told their *** to clear the damn code ya know? so they did and the light was off for maybe a week or so then one day came right back on....ive just learned to deal with the fact that my 100 dollars was a waste. the mechanic told me its nothing to worry about, it was just a small like evaporation code or somethin that was thrownSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
But dont most of you get your SES light taken off with it? Sounded like most of you had good luck. Anything I should do?2003 Nissan 350Z Touring Coupe, Daytona Blue, Frost leather interior, navigation, 18 inch wheels, M6, fully loaded, intake, crank pulley.<br /><br />Previous cars:<br />1991 Mustang (347)<br />2002 RS Camaro<br />1985 IROC-Z (305)<br />1994 Camaro convertible V6
my advice would be not to get it, if u waste the $100 to get the light off, big deal its not gonna hurt ur car a substantial amount if the light is on, i heard that if the light is on for a few years then ur car starts acting screwy. but i wouldnt bother because they didnt work with mine.SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Well I took my car to Autozone and they reset the code. Actually it does hurt your car with that code because it screws with your air/fuel ratio. Thats what I was told anyway. My light is off now.2003 Nissan 350Z Touring Coupe, Daytona Blue, Frost leather interior, navigation, 18 inch wheels, M6, fully loaded, intake, crank pulley.<br /><br />Previous cars:<br />1991 Mustang (347)<br />2002 RS Camaro<br />1985 IROC-Z (305)<br />1994 Camaro convertible V6
<blockquote>quote:</font><hr>Originally posted by Red94Camaro:
Well I took my car to Autozone and they reset the code. Actually it does hurt your car with that code because it screws with your air/fuel ratio. Thats what I was told anyway. My light is off now.<hr></blockquote>
dont worry..
it will be back..
[ July 10, 2003: Message edited by: AllTheGoodNamesAreGone ]</p>
No it should not affect your A/F ratio... that is affected by the readings from the O2's in each manifold. The pre and post cat O2's are there to make sure the cat is doing it's job.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
$100 bucks!!!! Dayum, yall got ripped. I got mine from zzperformance for $46 shipped to my door. I plugged it in disconnected the battery for like 30 minutes, hooked it back up, cranked it up and POOF! the cursed SES light was gone :D . Yall should try this I guess, if not it's no real biggy. My car runs better though with the SES light off. Good luck yall. [img]graemlins/fluffy.gif[/img]
[ July 10, 2003: Message edited by: Redsix ]</p><b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
Ok.. at this point i gota give my obigatory.. if you have a 2000 car or newer you may (and probably will) set off an ses light with the SIM!!
you will likly get a high voltage error.. i only know of 2 people who have a 2000 or newer car that did not gotten the error.. and probably around 9 that got the high voltage error..
<blockquote>quote:</font><hr>Originally posted by speedy-v6-camaro:
He had a code at first because he never got it reset. The code won't go away unless it gets cleared or the PCM reset.<hr></blockquote>
are you talking about me??
if so you are nuts.. i clear the code on an almost weekly basis..
<blockquote>quote:</font><hr>Originally posted by AllTheGoodNamesAreGone:
if so you are nuts.. i clear the code on an almost weekly basis..<hr></blockquote>
no, you are nuts if you think by takeing a fuse out or disconnecting the neg terminal, "clears" the code. if you dont have it put on a scanner the code will always be stored, i guess kinda like on the back burner in a way. the only way to clear a code is with autotap or the dealer or some sort of scanning tool.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
