hearder gaskets - FirebirdV6.com/CamaroV6.com Message Board
hearder gaskets
  • hearder gaskets
    i have heard that the gaskets that come with the pacesetter headers are S%#@
    my question is will factory gaskets fit paccesetter headers? would it be a good idea to buy a new set of gaskets? where, and what type should i get?
    i should be ordering headers sometime next week, I finally got a little bit of cash to spend!!!
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    You heard wrong.
    Matt
    1998 Mystic Teal Camaro M5
      lurn too speel monkee ;)
      The confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
        i ended up throwing mine away, probably more because i thought i heard a leak than because it was actually leaking. i just went to the parts store, got some rubberized gasket paper, and cut my own.
        Visit My F-Body Page
          Originally posted by 98Camaro3.8:
          </font><blockquote>quote:</font><hr />Originally posted by matt3989:
          You heard wrong. </font>[/QUOTE]yep, common mistake....but still a mistake [img]tongue.gif[/img]
          2000 3.8 A4 Pewter Camaro
            yea id say use the pacesetters, i wish i woulda instead of Fel-pro.
            99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
              No problem with my pacesetter gaskets yet, I did use some gasket sealer when I put them on (not sure if that helped or was even necessary). Ohh yeah, and I read somewhere that you should soak them in water the night before you put them on (I did that too).
              Old Car = 12.679 @ 106.5 on 150 dry shot.
              New Car = 2010 3.6l 304hp Camaro
                yeah i did some searching and research and realized that its the EGR people have problems with not the header gaskets
                did i get my facts straight this time?
                  yes. pacesetter gaskets are fine around the headers, just the EGR is leaking with 98% of people using pacesetters.
                  Dave:
                  00 Supercharged Camaro - RIP
                  97 Turbo Camaro - Sold
                    That is very true. [img]smile.gif[/img]
                    Matt
                      What is a EGR? And how serious is the leak?
                        Mine pacesetter gaskets worked good. They didnt leak but after about 15,000 miles my driver side blew out and passenger side after a little while after.
                        I have felpro'd now and they tick away leaking. If you cake them in gasket sealer and let them set up for a little while before putting them back on you can keep them from leaking.
                        Does anyone know where i can get some more pacesetter gaskets? part number or link?
                        2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
                          Felpros will definitely leak with Pacesetter headers. I discovered why a while ago and made a post about it with pics.
                          Part number for Pacesetter gaskets on Summit is PSM-G7209.
                          Matt
                            ok guys, 2 questions..... 1) so those flimsy pacesetter gasket do work? I bought the stock 3-ply metal ones from NAPA with the intention of installing them, but if the concensus is that they aren't necessary I won't... and 2) if I use that ultra-copper sealer around the EGR will that work?
                              i use the sealer and it works fine, however other people have had the problem of it burning off cuz of the heat and it leaks/ticks again..
                              and yes they pacesetter gaskets are fine. ive had mine on 7-8 months without problems *knock on wood*
                              Dave:
