I'm gonna put a new thermostat in, but i was just wondering if I should go with 160* or 180*. I heard that the 160 can set off some codes since it may think the engine is not warming up correctly. I also heard that the actual operating temp is higher than 160. Is anyone running either a 160 or 180, and can you let me know what you think
160* Thermostat
some people get the code with a 160. ihave never heard of anyone getting a code with a 180. they are only a few bucks so if you realy want a 160 consider it a test. if it doesnot work then try a 180.
i would suggest tracking gas mileage before and after the 160.
the car will not stay at 160 and to be most effective you want to recalibrate the fan turn on/off temps as well.
my engine does run about 10 degrees cooler with the 180 degree stat vs the stock 195 stat.
I have an 02 and I got a code and it caused my temp gauge to stop working. The only way to fix it is with tuning software to delete the code.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
Originally posted by dmw319:
i run 160. no SES, no problems. *thumbs up*
You can fix it on '01-'02 just like little G said but if you search I think other people figured out how t do it with something else.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
If you run a 160 and have a problem, I can send a resistor to put in your IAT (18KOhm resistor) that will fix the problem. $1 to cover postage and it's yours. I have to use the resistor to make mine work right [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
Originally posted by Chris Camaro:
my 2000 3.8 has a 180 stock, if i replace it with a hypertech 180 degree thermostat, is it gonna be any different?
B) You have a 195° thermostat. Get at least a 180°. [img]smile.gif[/img]Matt
1998 Mystic Teal Camaro M5
i have a 160 with no problems but yes, your fans wont come on sooner and so you wont run at 160*
