how can they say cold air kit when its hot air? - FirebirdV6.com/CamaroV6.com Message Board
  • how can they say cold air kit when its hot air?
    With the slp cai the black tube is right by the radiator, and after 20-30 minutes the black tubeing is very very hot so how would the air actually be cooler if the radiator and the heat from headers and engine bay is heating it up?
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    My tubes never get hot on my SLP CAI...
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
      that tube acts liek a heat sync and takes as much of the underhood temps out of the inlet air as possible
      boost, you got it???
