Ok ive been doing searches and reading for about an hour now but I cant find any detailed explination on how to remove the MAF screen. Can someone please tell me how to? thanks, by the way i have a 1995 3.4 camaro
How do I remove the MAF screen?? please help
since noboyd else is helping you, you have two options
1: Stick a screwdriver in it and rip it out, you will not be able to use it again, but hey, you got it out.
2) Take a small screwdriver and pull the silver ring out first. Then , with the same SMALL screwdriver, stick it in oone of the holes and gently pull it outZaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
Before you start ripping your engine apart you better check if the 3.4 even has a MAF or any kind of screen. I don't believe there is one on the 3.4, only the 3800 (96-02 cars), that's why you probably couldn't find anything in your searches.
[ May 04, 2002: Message edited by: FirebirdGT ]</p>Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
The 3.4L does not have a MAF or a MAF screen. The 3.4L uses a MAP instead of a MAF.<br />RIP<br />1995 Chevrolet Camaro<br />3.4L V6 A4<br />Flowmaster 40 Series<br />K&N FIPK<br />Throttle Body Coolant Bypass<br />180 Degree Thermostat<br />3.42 Ring Gear<br />Steel One Piece Driveshaft<br />IAT Relocation<br />and a website <a href=\"http://www.geocities.com/jason_b298\" target=\"_blank\">http://www.geocities.com/jason_b298</a><br />New Ride 2000 S-10<br />4.3L V6 VIN W<br />auto <br />3.42 w/ LSD<br />more coming soon
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...5 hours ago
