Another flowmaster Q - FirebirdV6.com/CamaroV6.com Message Board
  • Another flowmaster Q
    Ok i have an all stock 1997 camaro and have a few questions:
    1.What is the American thunder part #for my car i also hear that theres only a resonator on the 1998 and up is this true?
    2.If it did come with one has anybody put an extra resonator on it as well?
    3. If i were to put a cut out on my car where whould it go before or after the cat?
    4.Which is the best high-flow cat?
    5.What is that sensor that will need to be change and where is it located and what do i replace it with?
    Sorry about all the questions im gonna try and search for some but alot of different things come up so hopefully i can get some feedback.
    thanks andrew
    1997 Black 3.8L Camaro RS {SOLD}<br />Mods:<br />Flowmaster American Thunder Cat-Back<br />Slp Cold Air Intake<br /><br /><br />2001 Dodge Durango R/T
    1. http://www.jegs.com/cgi-bin/ncommerc...07&prmenbr=361 Scroll to the second to the last one. I'm not sure why they would only say it fits 98-02, didn't know they changed anything. Here's pictures of the underside of my car: http://www.geocities.com/ttop34/UnderCar.html Compare and see if yours is the same, notice however, mine's not stock but everything is in the stock location.
    2. The V6 catback does come with a resonator from what I've heard. I found some tips which had resonators in them which I really liked at Midas but mine haven't rusted bad enough to replace them yet. I think that would help my exhaust a lot though even though I like how loud it is every once in a while, setting off car alarms in the parking garage and stuff.
    3.I think a electric cut out before the cat would be perfect for racing at the track or a deserted street but good luck finding a shop to install it for you. The most sensible place that I've seen is the bend right before the muffler in the back, easy to get to.
    4.The cheapest. If I were to do it over again and keep my cat, I would have just chopped off the end with a saw and had that welded up to open it up to 3" but I'm cheap like that.
    5. All depends on what your replacing. I believe you have a pre and post cat o2 sensor so if you replace the pipe that goes right there then your going to have to get that reinstalled. The exhaust shop can get a small bung to weld in there so that your o2 sensor will thread in. Mine was put in the first bend of the S pipe right after the cat. You might want to look under your car though to make sure it's the same.
    Take a look around at my site if you like, send me an email if you have questions, maybe I'll be able to answer them.
    1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
    • Manimal
      Coil springs
      by Manimal
      6 days ago
    • Manimal
      Newby here
      by Manimal
