would it benefit me to have one, what psi is our current one set at, and where can i get an adjustable one from for my 3.8? will the LT1 fit my car?
adj. fuel pressure regulator
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
It's been said that our stock FPRs are adjustable. Just gotta play with that screw on the back side of it. Stock should be around 50-55 PSI.Matt
1998 Mystic Teal Camaro M5
