I HAVE THE SAME SET UP AND I DOESN'T COME WITH TIPS, JUST TURN DOWNS. AND NO ITS NOT A TRUE 3" CAT BACK. THE I- PIPE TAPERS FROM THE 3" AXLE PIPE DOWN TO THE 2.25 S-PIPE. I HAVE ONLY HEARD THE FLOWS ON THE NET, NEVER IN PERSON BUT THE EDELBROCK SOUNDS VERY DRONE, AND IT IS WAY TO QUIET FOR MY TASTE. I PLAN TO SWITCH MINE FOR A SPINTECH, OR FLOW. NOT SURE YET.
98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
I have the Edelbrock set up and at first its a little low but when it breaks in it has a real good sound to it. So dont be disapointed right away it will get better with time :D
JR
1996 Camaro 3.8<br />Edelbrock Exhaust, SLP Intake, Bosch, Platinum +4 Plugs, Accel Wires, SLP fan switch<p>\"Let the good times roll\"
<blockquote>quote:</font><hr>Originally posted by 12secondv6: I love my edlebrock!!!!
It does need time to break in.
Also adding a high flow cat, headers, and converter make it wicked loud!!!!<hr></blockquote>
Thanks James, how long does it take for it to break in????
I dont ever plan on putting headers or a converter on this car, well not until I do the V8 swap at least. I just wanna have fun w/ the 3.8 then drop in the bad boy [img]graemlins/burnout.gif[/img]
