Qtec cutout - FirebirdV6.com/CamaroV6.com Message Board
Qtec cutout
  • Qtec cutout
    Is the cut out really worth the money? Cause i was looking at there site and there dyno numbers and i am not to impressed, based on what they got on the V8 i figure that i would only pick up like 5 horse using it. Am i wrong? Is it worth the money to buy it and then get it installed? Cause i know when it is open it is probably going to sound pretty damn ricey right?
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    acctualy i have a sutout on my car and it sounds pretty good.. it loud but it sounds better woth the cutout open then though the exhuast.. i would have never guessed it either..
    imho get a manual cutout if you are gunne do it.. stick it on right where the two pipes meet in the y-pipe.. its reallly easy to take off there.. and you dont really need any tools.. jsut gloves so you dont burn yourself.. its only 3 wig nuts..
    eletric ones are cool.. but htey are a PITA to fit becuase they are alot bigger then then manual ones.. and have a tendency to get ripped off by potholes..
    they also break alot.. all the qtec and qtp's i ahe seen have only leasted year before they needed to be serviced or repaired..
    so.. get a manual for $30 tops and be happy..
      On my 99 Camaro v6 A4, I went 2 tenths quicker and a solid mph faster......
      Eric
      2005 Mustang 4.0
      1996 Camaro Conv
      2000 Ford Excursion
      "Darkness Falls"
        If ya guys have any questions about the QTEC call us, ill help ya out. Its alot of fun as well as a proven power gainer :D
        This revelation, is the death of ignorance...<br /><a href=\"http://www.quicktimeperformance.com\" target=\"_blank\">www.quicktimeperformance.com</a>
          i have a cutout and its does help. your expectations are too high. it sounds real good too, it actually make my car sound like it has balls. give you the vibration and the sound. and the electric cutout is great cause you dont have to get on your back to open it up
          2000 3.8 A4 Pewter Camaro
