Well after putting a muffler on my car finally I discovered my pacesetter y-pipe was leaking badly. 20 washers and $.50 later the leaks were gone and the car sounds fine again lol.
Fix my leaking y-pipe
00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own riskTags: None
yea i just got rid of that problem after 5 hours of straight cruis'n and driving car hard. Took me 2 days and jackstands to figure it out.. not to mention closing up EGR leak and replacing stripped screw in header before that.99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
ok ok the egr may still be leaking but I can't hear it so I'm not worried at the moment. and I already had the bolt I snapped off in the block removed and drilled ;)00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...5 days ago
