Throttle body vacuum line--where is it?? - FirebirdV6.com/CamaroV6.com Message Board
  • Throttle body vacuum line--where is it??
    I don't see it at all--I've got a 2000 w/the electronic tb and all I see on the passenger side are the electrical connections to the tb and the MAF--help anyone??
    --chris--
    Talk to Blazzin Joe here on the boards, he'll be able to help you out.
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
      If you are about to use seafoam, you can use the large vacuum line that connects to the brake booster on the driver's side. It is big enough to put a small funnel into so you don't make a huge mess. Ttop34 and I used that one when he used seafoam on his car.
