Just installed my SLP-CAI and I can't plug in the air sensor into the new intake because the wiring isn't long enough. The outlet is on the opposite side of the stock intake. Do I have to re-route the wiring? I'm totally clueless as to how to do that! Any suggestions would be helpful. Thanks Pickle
Re-routing wiring for SLP-CAI!
Did you change your stock air lid with a whisper lid when you installed the CAI?
If you just installed the CAI you shouldn't have had to remove the air sensor.
However, if you did install the whisper lid the air sensor hole should be on the same side. It is a little tricky to get in but a little bit of cussing and some imagination should help you get it in.
If you didn't install the whisper lid I am a little unclear why the air sensor is an issue.
Could you clarify?
Best RegardsSLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
<blockquote>quote:</font><hr>Originally posted by mjparme:
Could you clarify?
Best Regards<hr></blockquote>
This only applies to 98+, Pickle's got a '96.<a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 hours ago
