How do you know if your O2 sensor is going bad?
O2 Sensor question
<blockquote>quote:</font><hr>Originally posted by nitrox28:
It stops sensing O2. ;) <hr></blockquote>
:rolleyes: Newbie, if you're not gonna help, don't reply at all. Speedemon, it will usually trigger the SES light. Autozone can scan the code for you for free.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
O2 sensors should be changed on a maintenance schedule. I believe that the interval is about 30K miles for the single wire O2's and 50K miles on the newer ones (?4-Wire?). You can have the O2's checked at Autozone or with Autotap or other computer diagnosis machines that will give you a sensor readout. You will want the voltage from the O2 sensor to stay between 100 and 900 mV. If it is out of range, you will probably need new ones.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
You need to watch it. Auto Zone told me that my o2 sensors went out. and that i only had 2. welll i have 4. and turns out, took it to a mechanic and put it on the diagnostics mabobber, and my whole catalytic converter is bad. Seen it coming. o2 sensors read fine and dandy. [img]smile.gif[/img] [img]graemlins/fluffy.gif[/img]vRrOoOoOoOoOOooM
<blockquote>quote:</font><hr>Originally posted by Firebirdbabe420:
You need to watch it. Auto Zone told me that my o2 sensors went out. and that i only had 2. welll i have 4. and turns out, took it to a mechanic and put it on the diagnostics mabobber, and my whole catalytic converter is bad. Seen it coming. o2 sensors read fine and dandy. [img]smile.gif[/img] [img]graemlins/fluffy.gif[/img] <hr></blockquote>
This is true with many sensors on the car. Use them as a guideline for fixing problems. Dont jump to conclusion thinking that they are bad when their error code comes up. If you get a "Idle Air Control Valve can't set idle RPM" look beyond the sensor first...it could be a vacuum leak.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Well the reason why I ask, is I installed an A/F ratio gauge and I'm 99% positive that I tapped the right wire according to the Haynes manual, blue I think, and I never see higher than stoich, even at WOT. Which makes me wonder if my O2 sensor is going bad.<a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
