Magnaflow high flow cat - FirebirdV6.com/CamaroV6.com Message Board
  • Magnaflow high flow cat
    got one put on because the old one rattled, so i figured it was clogged and doonnee
    went to the shop, indeed it was, so i get the high flow magnaflow cat in, and guess what, it rattles...guy says it is because of the heat shield because they arent made good or something, i dun remeber
    hell i got rid of the old one because of the rattle, adn the new one does the same damn thing...arrggg
    so what the hell should i do???? anyone??
    2000 v6 A4 Camaro Y87<br />Magnaflow HighFlow Cat., Flowmaster American Thunder Cat. Back system, K&N Aircharger CAI, Fuzzy Dice :)
    Get rid of the heat shield or weld it to where it won't rattle. By the way, where did you get the cat and how much was it?
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
      I had the same problem with my high flow cat so I ripped the heat shield off. You won't have a problem by doing that...there is still a heat shield on the underside of the car where the cat is.
        hmm..can i do that or should i take it to the shop??
        i got it off ebay by some dude named like jehovanissi or something like that for about 50-60$, so yea i got a pretty good deal. The guy at the shop welded the outside but it didnt help, he said he could jam some pieces of wood in there so it wouldnt rattle, what do u think about that?
        or anything else u can tell me about rippin off the heat shield, pros, cons, anything
        thnx
          They are not attached too firmly. You can take a pair of plyers and bend it back and forth (with it off of the car) and get it off.
            This must be something that is 98+ because my magnaflow cat does not rattle, nor does the heat shield [img]smile.gif[/img]
            <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
              Don't go blaming the 98+...mine doesn't rattle.
              Cardomain
                well mine is welded on right now so what to do????
                i really dont feel like paying the shop to cut it off, rip off the heatshield, and weld it back on .....
                  If the heat shield is that loose, you should be able to get it off with some pliers even on the car.
                  Magnaflow cat here, no problems.
                  \'01 Mineral Grey SVT Cobra<br />-former F-body owner
                    shop said its not that the heat shield is loose, is that because of the way it is designed that it clangs on the other part or something causing it to rattle
                      no, its designed fine. they dont have it hung/ adjusted correctly.
                        I'd agree, sounds like a problem other than the cat. I also have a 3" Magnaflow and the shield that came on the cat is welded tight. It could be the shield that is attached to the car above the cat, or a number of other things.
                        Hmm, now that I think about it I used to have a nasty rattle from the exhaust and it turned out to be a short 6" piece of shield that was clamped on the intermediate pipe just in front of the axle. I'm not sure what it was meant to protect but one of the clamps had rusted loose and the thing was vibrating so I just ripped it off.
