Cutting Rattling heat shields - FirebirdV6.com/CamaroV6.com Message Board
  • Cutting Rattling heat shields
    What do you use? I have tried tin snips but its hard to get in there.
    1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
    Unbolt them. I put cork gasket material under them and reattached.
    \'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
      I used pliers (regular and needle nose) and a flat head screwdriver. The heat shields on my cat were formed around a lip. I had to pry the edges w/the screwdriver and "work" it off w/the pliers.
      --Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
        I installed a bigger I pipe and it is very close to the heat sheild, I want to cut away the 1/4 of an inch that is close to the I pipe. What do I use?
          Anyone?
            I would suggest taking them off. Cut alittle, then put them back on. Repeat if needed.
            As for what to use to cut them? Hack saw or a grinder of some sort maybe.
            http://seppo.hopto.org/
