will putting the new tubular manifolds off the 2000+ cars give any better flow than the ones on the 98. or give more space around the engine.
exhaust manifolds
I don't know about your 98, but my 96 had AC components in the way on the passenger side. It's hard to tell without removing the old manifolds, but just so you're forewarned.
Look at headers that are made for our cars - if you notice how, on the passenger side header, the front pipe doesn't go down right out of the engine, instead it travels back, parallel to the engine. Picture (pacesetter's 3.8 prototype from AZ3.8Camaro)
Now, if you look at the tubular manifolds, the front-most pipe travels down right off the engine. This is where I ran into problems - there is not enough clearance there (on my car). My 2002 manifolds. || Upside-down.
This is only for my car, every car is different, and your AC stuff might not be anywhere near the exhaust manifolds like mine is. Good luck, and feel free to contact me.www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
does anyone know if the tubular exhaust manifolds will work on a 98. or will anything be in the way. also can you use standard sparkplug wires or do you have to have to use the same style as gm oem.1998 Onyx Black Camaro A4 2.75\" Custom Flomaster Catback, Removed Cat, MTI Lid, Jet Power Programmer, K&N air filter, 1LE aluminum driveshaft, maf screen removed.
<blockquote>quote:</font><hr>Originally posted by marcus_3050:
does anyone know if the tubular exhaust manifolds will work on a 98. or will anything be in the way. also can you use standard sparkplug wires or do you have to have to use the same style as gm oem.<hr></blockquote>
If someone can post some pictures of the area in question, I might be able to tell.www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
i am debating getting the tubular also....1999 Camaro Silver 5spd<br />Appearence Mods:<br />-Clear Corners -Tail Lights off a 93-96 Camaro -Painted Black Calipers w/ Silver Camaro Decal on front ones -Black Camaro Rear Fill Decal -Silver Camaro Front Fill Decal -Painted Silver Interior Pieces -RKSport Shift Knob<br />Performance Mods:<br />-Eibach springs -Whisper Lid -Removed MAF screen -Free Ram Air -Trans Am Dual Exhaust -3\" Cutout<br />Stereo System:<br />-Eclipse 8v Head Unit -Eclipse 87series 12\' Subs -Rockford Fosgate 800wt amp (subs) -MTX 225wt amp (highs)<p>AOL IM is jay eub, msn messenger is banks_2003@hotmail.com
Im almost positive its a direct swap. I was going to do it and had no problems w/ it mine compared to my friends 00 bird. But if your gonna upgrade just go w/ the headers and not the tubular manifolds. If you have a 99+ fody just keep the stock manifolds cause there will be minimal gains between the two like 5 hp. But for us pre 99 cars we will be better w/ headers and probably no doubt that we would feel the difference. IMO.2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
<blockquote>quote:</font><hr>Originally posted by W68Firebird97:
Im almost positive its a direct swap. I was going to do it and had no problems w/ it mine compared to my friends 00 bird. But if your gonna upgrade just go w/ the headers and not the tubular manifolds. If you have a 99+ fody just keep the stock manifolds cause there will be minimal gains between the two like 5 hp. But for us pre 99 cars we will be better w/ headers and probably no doubt that we would feel the difference. IMO.<hr></blockquote>
You're saying that your 97 bird looked just like your friend's 2000? I wonder if they did actually change the AC around that year...www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
I woulda sworn I saw at CIA that they said they got better performance gains on the non tubulars. and Ive seen dynos of the stock cars and the ones with similar intkaes the no tubulars have had better power curves and numbers. Ive been posting this everywhere. From what I see the non tubulars are better. Thats just what Ive seen. Its kinda like the 98 99 LS1 has a more agressive cam timing but the 2000-2002 has less agressive cam timing but the LS6 manifold- Same power on the dyno.I think that its one of the many little things that were changed between our years. 99- have no ram air type intake but better manifold new has nicer intake worse manifold. if u ask me.97 Special Edition Bird , Short bus stlye special
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...6 hours ago
