does anyone know where i can get only a y pipe for my 01 v6 3.8 camaro? i can only find a header and y pipe combo. really all i am looking for is to get ride of my cat. anyone have any ideas?
want to get ride of my cat conv
Originally posted by ellik:
I have a high flow cat band clamped in at either end so that I can pull it out and slide in either a strait pipe or cut-out whenever I want.
I would just cut out the cat at the front weld, cut enough of the stock 'S' out to get a reducer in there and then weld in a 3" high flow cat. you are going to want to leave the 02 bungs in there or put in sims, being in Philly you are going to need to pass the OBDii code based emissions and visual inspection for a cat\'01 Mineral Grey SVT Cobra<br />-former F-body owner
i think you could buy the slp installation kit which has an S-pipe in it, buy the high-flow cat (for emissions and swap for a strait pipe), and then clamp it in. im not sure I would spend that much to do it though, and it will probably take a little bit of fab work anyway.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...7 hours ago
