I wish there was more competition, but unfortunatly there is not. I wish there was someone else out there that made decent headers for close to the price pacesetter is, if there was I would STRONGLY suggest to any person to get those.
Pacesetter Woes (Last Update: 6-2) FIXED!
I personaly, am going to take a shot at bending out the "Y" of the Y-pipe, the amount I need. I *think* i should be able to pull it off with out wrecking the coating, or any welds, if I do the pulls in the right places.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
Originally posted by DannyV6Camaro:
i think i need to give them a call, cause i brought mine in the GP to, but havent installed them. I wonder if they will weld the extension on for me if a send it to them???? what do u guys think???Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
i think i need to give them a call, cause i brought mine in the GP to, but havent installed them. I wonder if they will weld the extension on for me if a send it to them???? what do u guys think???1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
Originally posted by Linxs:
</font><blockquote>quote:</font><hr /> I personaly, am going to take a shot at bending out the "Y" of the Y-pipe, the amount I need. I *think* i should be able to pull it off with out wrecking the coating, or any welds, if I do the pulls in the right places.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
Originally posted by hawgs:
What does that mean for us though?
I need to call now since they admitted it was their design. I need some sort of compensation for the money and time I have spent correcting their error.
Oh.. and May is the 5th month, not the 6th. [img]smile.gif[/img]1996 Camaro, Built Motor(L/C,Cam, Ported), T66 FFF Kit, N20, 36 lb. Inject., FMU, 255 Walbro, 00+ Manifolds, SFC, LCA, Tubular K, Adj. PHR, 17x9.5,x11 Chrome ZR1, Front 35MM/Rear 21 MM Swaybars
Originally posted by DavidSiri:
</font><blockquote>quote:</font><hr />Originally posted by hawgs:
Originally posted by Distephano:
</font><blockquote>quote:</font><hr />Originally posted by Linxs:
</font><blockquote>quote:</font><hr /> I personaly, am going to take a shot at bending out the "Y" of the Y-pipe, the amount I need. I *think* i should be able to pull it off with out wrecking the coating, or any welds, if I do the pulls in the right places.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
I sent pictures to people who asked for them. I hope it helps...
[ May 21, 2004, 05:10 PM: Message edited by: Linxs ]Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
hm.. i have used rksport coated headers sitting in storage.. how are these inferior to pacesetter? The previous owner said he had no problems, just upgraded to an Ls1~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
i just emailed pacesetter, the company i ordered thm from, and the person i talked to while my headers were in back order to see if i could find out if my headers are flawed too. do you guys know of any way i could see if they dont fit right without actualy putting them on cause i dont have any way to do it for awhile and i want to get this taken care of before any warranty or something goes out.
o' by the way, i recieved mine the 4th of may. isnt that about the same time as you guys which leads me to believe i got bad headers too
do you guys know if there is some type of way that i could know if my y-pipe is ****ed??? maybe some type of number or code in it or any info i might have recived?
Yes, I got mine around May 4th.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
The reason they are making changes to the Y-Pipe, is because it will allow for the greatest range of adjustment, allowing them to keep being sloppy with their welding. :(
As for the RK sport headers. If they have the flange problem corrected so they don't leak, then Yes, I'd go with those over the Pacesetters.
The way I personaly feel now is, there is not a decent priced header system for our cars, that is made nice.
</font>- Pacesetter
Sloppy, instead of correcting the sloppyness, they made adjustments to the Y-Pipe to allow for it.</font> - RK Sport
They leak from the factory, have to have mods made to stop this.</font> - CAI
(Or is it CIA... I forget) Too damn expensive. There are other things I'd put that much money into first.</font>
So, if I had it to do over, I think I would have put my $225 into other things, like a Z28 rear end or a shifter and some other little goodies.
[ May 21, 2004, 02:43 PM: Message edited by: Distephano ]1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
- Pacesetter
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
