Upper and Lower Intakes from 2000 on a 1997?? - FirebirdV6.com/CamaroV6.com Message Board
  • Upper and Lower Intakes from 2000 on a 1997??
    Will the upper and lower intake manifolds from a 2000 engine fit on a 97? As for the throttle body, could you just attach it to the new manifold and it would no longer be angled?? Are the bolt locations the same? Could you hook up the cable assembly correctly with the throttle body no longer being angled?? Please need help quick, very interested in doing this!!
    C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
    i was wondering about that- i havent seen any aftermarket upper/lower intakes for our 3.8s... errrrrrrrrrrrr
    can anything be swapped out of other engines?
    -Justin-<br />Red 1996 Camaro RS- Wrecked 11-1-03...<br /><br />1991 Camaro RS
      zooomer is currently producing new intakes for the L36, they are going to be offered in his stage 2 package and should net 200rwhp with the full kit with proper tuning
      97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
        The two manaifolds are pretty different from each other. The biggest difference being the TB which canot be interchanged. You can motify the manaifolds yourself by porting them and ploishing them with a dremal, or having somebody eles do it.
        2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
          Ok, well back to my original question, will they bolt up correctly to the heads and such much like my manifolds do and could I connect my throttle body to the new intake manifold (would go on straight now) and rehook the cable. I would prefer not to waste $$ on new intakes if they are not going to fit. Please post some answers as the sooner I find out for sure the better, thanks again. (I'll worry about porting later, just wanna make sure they'll fit before I buy them)
            The lower half will work fine, but the upper half will not.
