Got to the track yesterday and started making my runs with the cutout open and sure enough those godamned 15.8's started rolling in again, I let the temp cool down a bit and tried a run w/ it open again and same results as I had when it was warmer. So I figure ill just close the cutout and see if that doesnt make it run a little better. The first thing I noticed as I lay on the track (in my white pants) is that it is nearly impossible to get two hands underneath the car to the cutout. So being the coordinated person I am I managed to get the cap on and tightened down with one hand (took me a while though). I tightened it as best I could with my fingers and then went for the ratchet. As it turns out the ratchet was sticking in the loosen position so I said screw it and tightened the nuts again with my fingers.
My first clue that something was wrong should have been when I started the car, it made the most horrible raspy tin can POS sound that I have ever head and continud to make it as I reved the engine. I thought that it was because there had been no exhaust running through the muffler in well over three weeks, but I was wrong.
Well after some disgusted looks and words from onlookers I rolled out onto the line and watched the tree. I hit my light almost perfectly (.607) and got to the end of the track, victorious for a change. As I get onto the return lane I hear a large Bang and then a series of rumbles. The rumbles was my exhaust and the bang as you most likely guessed was my cutout exploding. I didnt bother to stop and look for it at that time because I didnt want the track overseers to shut the lanes down and send the ambulance to me (has happened to a friend of mine, everyone at the track will hate you if your not dead.)
The horrible sound from my exhaust with the cap on im sure was caused by leakage of pressure through the not tightly shut cap, thus leaving almost 0 pressure in the muffler allowing the gasses to bang around in the thing like a cheap tin can. I eventually found my cap the next run, the force of the exhaust had striped the threading from about 1/8" from the head all the way to the bottom. leaving the bolts nice and shiny but useless. The cap itself was fine, thank god it didnt blow in half or anything, I might have lost my quarterpanel had that happened. Anyways to make this into a moral story ALWAYS TIGHTEN YOUR CAP BEFORE YOU RACE, USE A RATCHET OR IT WILL EXPLODE [img]graemlins/dunce.gif[/img]
[ October 10, 2002: Message edited by: Dirty8-un-Dreds ]</p>
