I read that the only difference between the whisper lid and the stock lid is the ridges on the underside of the stock lid. If this is the case, can I grind the ridges off my stock lid and save myself $125?
Whisper Lid Question
<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>Tags: None
There are other differences, but yes you can do that.
Also remember that the Whisper Lid gets rid of the air silencer. That's where the big difference comes from. You can make that yourself with some dryer ducting if you want.
The exit from the lid is also larger on the Whisper Lid.
Plus it looks pretty damn good. :DMatt
1998 Mystic Teal Camaro M5
as 98camaro 3.8 said, you can shave the lid and replace the silencer with a piece of 3 in pvc pipe. this will give you noticable gain for mininmal price.
i did this and then bought a whisper lid. the lid did give me a little more thottle response.
if moneys tight just shave the lid(dont grind it, just take a hammer and run it down them the break easily, and you dont waste your grinding wheel), replace the silencer and do the !FRA mod. you notice a pretty big difference. the !FRA is nice on these cold dry nights.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
I used an air tool with a steel round plate on the end to grind all the ridges off, smoothed it out with sand paper and washed it. Don't really knowtice any difference in throttle response. I'll try adding the pipe to it and see how that turns out. I will be buying a whisper lid eventually but before I buy one I would like to buy an exhaust and NOS system. This will do for now thanks!<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
Remember guys, he's got a 98. ;)
You won't be able to use a PVC pipe on yours. You'll have to get some kind of ducting.Matt
Ah, the dreaded angled TB. Sucks for you guys. Anyway, use some ducting to get rid of the bellows and shave the air box lid and you will be happy. Since you have a 98 firebird you can do something that is a little cooler than the FRA mod, check it out here http://www.camarov6.com/ubb/ultimate...;f=29;t=000011 . Its a bit more work but it will keep you filter cleaner than the FRA mod and will get you just as much cold air flow to the filter.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Cool! That seems like an easy mod I can do in a couple hours, I have a set of air tools and an air compressor so it should be no problem thanks for the info.<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
Just got done with the ram air mod... About a week earlier I put in a SLP CAI and a K&N air filter, I knwoticed a greater increase of horsepower from the ram air mod then both the other modifications combined, thanks T-Punk!<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
