If you mean the radiator shroud, no I did not remove it. The silencer assembly for the stock airbox is completely removed as you can see in the picture, and it is a tight fit with the radiator shroud attached, but it definately does fit. I wouldn't market a kit where you had to ghetto-ize the car to make it work :D
**PICS UP! - New Cold Air Intakes Available
1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
Originally posted by cboney2003:
If you mean the radiator shroud, no I did not remove it. The silencer assembly for the stock airbox is completely removed as you can see in the picture, and it is a tight fit with the radiator shroud attached, but it definately does fit. I wouldn't market a kit where you had to ghetto-ize the car to make it work :DRed 1998 Camaro 3.8<br />K&N and Home Depot<br />2 12\" JL W3v2 Subwoofers<br />-more audio stuff to come-
