I am planning on buying pacesetters, and I was wondering what else I will need to buy so that everything is fine when they are hooked up?
Question about headers
If you are doing them yourself then you just need to make sure you have all the tools to do it.
Aside from that, I needed one spark plug wire that had 90 degree boots on both sides instead of just one 90 degree and one straight. Some people said that theirs already were like that though...so if that's the case then don't worry about it.Shawn<br />2002 Silver W68 Firebird
do a search you will come up with alot of stuff96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
It comes with bolts.
Unless CAMAROWIDBASS is referring to collector bolts, which would be a good idea. The ones that came with the headers didn't have enough thread on them.
[ January 28, 2004: Message edited by: 98Camaro3.8 ]</p>Matt
1998 Mystic Teal Camaro M5
