my damn exhaust is hittin everything and sounds like ****..so i get under the car and i see that the I pipe is hittin the driveshaft :mad: and the over axle portion is hittin the pan hard bar when i hit a slight bump... the i started the car and let it idle and go under the car and the leaks around the muffler are everywhere..grr :mad: im soo pissed off im going up there tomorrow and it better be fixed with out costing me a cent.. :mad:
grrrr
anyone else have problems and have any quick fixes?
well i got mine taken car off..i took it in and told him it was messed up and they welded some more hangers on it so its now rattle free and no more exhaust leaks..YEAH!!!!
Mickeys that isn't the tips. Do you know that adjustable bolt hole on the passenger side of the car near where the tip bolts on? Its the sharp corner of that thing rattling against the stock hangers. I put a piece of rubber on the stock hanger to stop the rattle.
1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
They relocated my stock hangers. They refused to make the exhaust too tight. Said it would send too many vibrations into the car, and the pipe could break if hung too tight. I have to make a real sharp corner to make it bump, and then it barely does it. My first aftermarket muffler banged like a mofo. I hear that a pair of ls1 hangers are better than ours though.
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
I had my 3 inch installed at Meineke, the guy there did an excellent job. It doesnt hit anything and there are no leaks. Im sorry but it sounds like the guy may have goofed up the install.
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
