ok I have picked out an exhaust that I want to get. Each piece has been picked so I'm ready to start buying. While in the midst of this. I realized that headers are basically in the same area as the exhaust. If I got a catback exhaust and had it installed, would I have to undo previous welds to put on the headers?
Basically I'm asking if I should get the headers and exhaust at the same time to save work
~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
i got my headers, I pipe, S pipe and muffler all put on at the same time. The sound is unreal at idle. So i would recommend doing it at the same time but if you dont wanna spend the 300-500 dollars for headers then dont, the power gain isnt the best, maybe 5 hp 7?
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
