Is there a throttle body coolant plug for our car? - FirebirdV6.com/CamaroV6.com Message Board
  • Is there a throttle body coolant plug for our car?
    http://www.zzperformance.com/product...3f7b81952a8ae4
    They sell one but they said it won't work for us.
    That does not fit. If you look closely at the picture and have your TB off or a gasket in hand you will see that (ours vs FWD cars) coolant channel in the TB is shaped differently.
    So, it is a rubber plug....Take off TB. Fill the TB's coolant channel with RTV blue...tamp it in good with head of a nail. clean up the endges. Let it cure good for 24 hours. (it is a big gob of goo so make sure and let it cure fully) VOILA! No more coolant in the TB because the cavity is already full of RTV blue silicon.
    [img]smile.gif[/img]
    01 Firebird A4 3.42
    Powerdyne @ 6 PSI
    and other mods
      25$ for piece of rubber? [img]graemlins/twak.gif[/img]
        Question: How does blocking coolant keep the TB cooler?
        Red 97 Camaro
          Because the coolant is at 180*+ and without it, your throttle body would be closer to the 80* air being pulled through it.. coolant _heats_ your tb.
          (The coolant is there to keep the tb from icing up in cold weather)
          2001 Pewter Firebird Y87, M5
          Go Sabres!
            So...considering that a TB spacer works...if i am going in there to install the TB spacer, isn't it worth my time to plug up that whole when i am in there anyways, or just a waist of time?
            2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
              If you're going in there to install a tb spacer, the spacer will keep coolant from getting in the tb. For the money, the tb spacer is one of the best mods you can do. I got an extra 2-3 miles per gallon after i installed mine.
              2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
