I have a B&B Triflow catback, which is 2 1/2". My question is if it is fine to go with a 3" in out diameter magnaflow cat and S pipe, or should i stay with a 2 1/2???? Any comments appreciated.I got a $15 coupon from ebay to use at any store and it ends 10/31 and i would like to order before than. Thanks again.
BTW, Its a 01 3.8 w/ Y87
Ryan
Originally posted by fbird01: I have a B&B Triflow catback, which is 2 1/2". My question is if it is fine to go with a 3" in out diameter magnaflow cat and S pipe, or should i stay with a 2 1/2????
Might be a good idea to do a quick search. There's been quite a few debates, and they usually get pretty long so there should be alot there if you try to search.
I am going to be buying an exhaust system today.. hopefully from summit,from what I've read the magnaflow sounds the best on 3.8L...
They are not 3" though..
Intermediate Pipe Diameter (in): 2.500
Tailpipe Diameter (in): 2.500
Tip Diameter (in): 3.500
The flowmaster isn't a 3" either...
Tip Diameter (in): 3.000
What is a good exhaust I can buy for around 400-450(Borla is out of the question.. way to expensive) that has a 3" catback setup?
Is a 3" that much better then a 2.5"??
CamaroRob said something about a converter... where can I buy a converter kit for a magnaflow?
[ October 25, 2005, 12:23 PM: Message edited by: Matt G ]
Go with the LT1 system, Magnaflow's comes with the S pipe as well. Bolts right up the same. Look on e-bay for a carsound (magnaflow's parent company) 3" cat... mine was 35 bucks
Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
