I am planning on getting a total ram air set up sometime soon. I am planning on getting the hood and all. So my question is, where did you all get your ram air kits, and what brand, if any, seems to be the best? Lastly, if anybody has cool styles of hoods for a 1997 camaro, post the link to the photo, because I am still not quite sure on what style hood I am going to get! Thanks for all of you help!
Ram Air
don't think you can do it with the bent throttle body and all.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
If you have a cold air intake setup, this is what i did, its not too difficult:
http://www.charm.net/~mchaney/ramair/ramair.htm
I went to a local hardware store, bought some heavy duty metal, but still able be bent, and bent it similar to that. The metal was like .49 a foot or somthing, not expensive at all, i just hope it doesnt rust. Ill redo it if i have to. Anyways, the way he did it on the site is a little different from a v6 setup i think. When you unlatch that panel at the bottem, first off i just cut it off. Then i measured the size using the panel that i cut off. I had to redo it just once because i mismeasured, but i think this gives a little better throttle response, and definitly flows in cooler air. So if youre looking for somthing simple and cheap, i would recommend this.97 Camaro<br /><br />K&N Hi-Flow CAI, Xlerator into Dual<br /> <a href=\"http://www.cardomain.com/id/camaaro\" target=\"_blank\">http://www.cardomain.com/id/camaaro</a>
