Ok I was Skeptical But I did the Free Ram Air Mod. WOW!!!!!! Throttle Response is Way Better My Exhaust Is Deeper and.. My 100 to 118 Is Damn near Twice as Fast. I gave my freinds Twinked out Jetta A run for his money in the 100 + Catagory . Man If anyone has not done this i suggest doing it. Its not hard. Major Diffrence.
FREE RAM AIR
I did the same thing to my Camaro the past few weeks. I also mid the Air Box mod. (Cut away) with my own cut away of the airbox silencer(So that it still feeds air from the side well. I felt more throttle resonse and it feels like I get more torque out of each gear before my torque converter shifts. My exhaust is a little deeper too. Great mod for only $0.99 worth of parts and a hours worth of work!
Hey Guys, What did you use to cut the bottem of the air tray with? I want to do this mod but im afraid that I might crack that plastic if i dont use the right thing to cuz it with. Also what did you use to cuz that plastic air baffle with? and are there any tips u could give me??-Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
I used a cutter wheel on a dremmel. Make sure you cover up everything to make sure nothing gets anywhere its not supposed to ;)
The plastic gets really hot when you're cutting it, it almost melts away. So be careful when you do it. Its not hot enough to melt your finger off, but it will make you jump.Justin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
I have a 97 Firebird, is their any way I could do this? is it better than Cold Air? I have a K&N cold air induction, but I can't install it untill I buy this induction elbow which cost 89.99, but SLP had one that looked the same but it was Oval on one end, and it was for 59.99, is this the same thing? will it work? or should I try the Free Ram Air thing? Any help or advice would be much appreciated. thanksThen: 1997 3.8L Red Firebird~SOLD!~<p>Now: 2002 Atlantic Blue Dodge Ram 1500
<blockquote>quote:</font><hr>Originally posted by AZv6camaro:
Hey Guys, What did you use to cut the bottem of the air tray with? I want to do this mod but im afraid that I might crack that plastic if i dont use the right thing to cuz it with. Also what did you use to cuz that plastic air baffle with? and are there any tips u could give me?? <hr></blockquote>
i definately recommend you just unscrew your lid and the 4 bolts and take off that whole section...and use a dremmel. Really easy and effective..2003 Fire Red Dakota R/T 5.9<p>V-Force Exhaust<br />Custom Cold Air Intake
<blockquote>quote:</font><hr>Originally posted by calvo:
How do you do/make the free ram air?<hr></blockquote>
You've already done it since you have the fast-toys ram air set-up. All there talking about is cutting-out the bottom of their air boxes, which us 98+ guys already do when we install the underhood cold air kits by slp or fastoys.<a href=\"http://groups.msn.com/WhoisNightRider/bluethunder.msnw\" target=\"_blank\">2002 Electron Blue Corvette Coupe</a><br /><i>13.083@108.23</i><br /><br /><a href=\"http://groups.msn.com/WhoisNightRider/redfire.msnw\" target=\"_blank\">2002 Metallic Red Grandprix GTP</a> <b>SOLD</b><br /><i>14.49@94.42 (Bone stock)</i><br /><br />2002 Black Convertible Camaro Z28<br /><i>times comming real soon!</i>
<blockquote>quote:</font><hr>Originally posted by 98Camaro3.8:
"Free Ram Air" is only for 98+ cars.
Matt<hr></blockquote>
You don't know what you're talking about. 93-97's can do it by making scoops under the front fascia to feed cold air into the filter area. Why are people going and reviving old threads anyways?
