I had an idea for this IAT mod that has so much debate... I hear that it's mostly useless except at WOT.
If you could somehow detect WOT, maybe you could put a DPDT relay on it. You know, like a window switch for Nitrous, but without a shut-off at high RPM's.
Is there a wire that is hot only when WOT is true?
If that is the case, the resistor could be put in line only when that wire is hot. (Bypassed otherwise)
Would it work?
-Brian
Would it work?
-Brian
