Exhaust Troubles - FirebirdV6.com/CamaroV6.com Message Board
Exhaust Troubles
  • Exhaust Troubles
    My exhaust has been rattling for sometime now. I ignored it for awhile, but now it's bad.
    The exhaust is hitting the piece of metal that crosses under it. Right below and inbetween the 2 front seats. I dunno what it's called but it's flat piece of metal and the exhuast is hitting that when I hit a bump, rough road, or at idle. At throttle it goes away.
    My visibility/access was limited but I think the exhaust itself maybe hanging too low there, or at least alot more flex (up and down) than I'd have imagined.
    I'll probably end up getting a whole new exhaust anyways, but thought I'd post to see if anyone knew what is wrong with it, or an easy fix for time being.
    easy fix? remove the plate.
    01 Firebird A4 3.42
    Powerdyne @ 6 PSI
    and other mods
      inspect the horizontal s pipe hanger. the rubber chassis mounted bushing should be in good shape. there is a piece welded to s pipe the make that connection. make sure all that stuff is good and not broken.
      01 Firebird A4 3.42
      Powerdyne @ 6 PSI
      and other mods
        How many times do I have 2 say this?? CHECK THE DAMN EXHAUST MANIFOLD BOLTS!! These things R, like every other GM bolt, complete crap an' WILL break on U. This happened 2 me an' I welded up the whole exhuast, got a new Cat. ,etc. So I'm tellin' U...if THIS happens 2 B your prob. all the "Hangers" in the world won't do U any good. An' U'll probably also have a ferocious exhaust leak O' which you're "unaware". *CALMS SELF* [img]graemlins/barf.gif[/img] Oh yeah...an' anybody that says "Oh...Jus' rip the heat shield off...", is an idiot.
