Ok in my slp cold air induction is my IAT sensor. In the beganing of the throttle body on the left is a sensor. Just above that still on the left is another sensor. Then on the right above that is the MAF. So which one is it?
Thanks, i need this idle problem fixed its bugging me.
On the passenger side of the engine, (assuming you have a 3.8), there are the two sensors you mention:
1) TPS Sensor- furthest to the front of the engine, and has three wires going into it that are red, green, and black.
2) IAC Sensor- connected to the intake, and sits a little higher than the TPS. The IAC Sensor has four smaller wires going into it.
