Does anyone know a trick to getting the fuel line off the fuel rails without using a disconnect tool ??
Fuel Iine help
the disconnect tool costs about $4.
GM/Ford - 5/16 and 3/8.
Push the two sections of fuel line together firmly...insert tool...pop... that is the trick.
Doesn't have to be a GM dealer. Alot of cars use the same style connector, so an auto parts store should have it....unless things are way different over there.Matt
1998 Mystic Teal Camaro M5
check out this link. about 1/3 way down the page I have pics of what the disconnect tool looks like. It is "ford/gm quick disconnect tool...5/16 - 3/8"
It only costs a few dollars...here in the states. Good luck. G
http://home.comcast.net/~grayman99/EFPS-Install.htm
