3.4L EGR resistance - FirebirdV6.com/CamaroV6.com Message Board
3.4L EGR resistance
  • 3.4L EGR resistance
    Hey, i'm removing my EGR system from my 3.4 to try to cool down the intake air temp and whatever, i've got a friend making the blockoff plates for it. But what i need to know is the resistance value for the solenoids, and which pins on the connector to place the resistor inbetween. Thanks for any help you guys can offer.
    1995 Blue Chevrolet Camaro <br />Dynomax Exhaust, Custom CAI w/K&N, Throttle Body Bypass, ACDelco Plugs/Accel 8mm Wires. Indiglo Gauges. BMR Stut Tower Brace, ASP underdrive pulleys, BF Goodrich g-Force T/A KDW\'s around. <br />AIM: STMIKEK
    honestly I am not sure we can do anything like that, The EGR constanly sends differnet signals and opens the solenoids at different rates, form my understanding the best EGR mod, is to leave it hooked up but not have it go into the intake.
      the point of the egr is to cool down the combustion chamber to reduce nox emmissions. it will also probably cause a lean condition at cruising speeds cause tha pcm alredy expets it to be there.
