3.4 Modified LT1 throttle body.... - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4 Modified LT1 throttle body....
    Ok, I have seen some of you guys with this but I do not know any specifics on it. Information would be greatly appreciated, such as pro's, con's, was it worth it, does it actually help performance wise, and does someone make them? If so.. who and where can I get them.
    \'94 Black Firebird<br />3.4 Auto :(<br />Big Block hood<br />17\" x 9 1/2\" Torq Thrust II rims<br />P245/55 Z-Rated Nitto tires<br />Custom interior paint.<br />Custom Air intake with heat shield<br />Magnaflow cat-back Exhaust System<br />Eibach Sportline lowering springs<br /><a href=\"http://www.realproexhaust.com/other/cootees.htm\" target=\"_blank\">www.realproexhaust.com/other/cootees.htm</a>
    i second that and would like to know
    My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
      The only one I have actually seen involved cutting the front off an LT1 intake and welding it on to a 3.4 intake... I'll pass.
        Maybe this is old news to you 3.4 guys but this guy did it using a 95 LT1 trottle body.
        turboz24
          NRT is the only place tha did that there where only a few cars that i am aware of that had it done v6blur(now viper98885 has it :mad: ) and tiago94 has one it is the lt1 tb with a modified 3.4 upper intake they no longer do our stuff so you would have to get a local shop to do it for you and they will be expensive if they will even do it alot of places won't touch it
          1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
            Hey Southern maybe you should talk to Curtis Walker(turboZ24). I don't know who NRT is but Walker did the intake himself or someone he knows did it. Either way were just talking about Aluminum. Speedshops Fab Aluminum intakes for engines from the ground up all the time and in this case the intake is already made just needs different flange welded on. If it weren't hard it wouldnt be worth doing, right?
              it is def. a good mod our tb's are soooo small i am going to talk to my local shop and see what they can do i would like to talk to that guy and see how much he could get mine done for if i ship him min
                What is the ID of 3.4 throttle body?
                  52 mm I belive
                  Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
