Having trouble installing whisper lid - FirebirdV6.com/CamaroV6.com Message Board
  • Having trouble installing whisper lid
    I have a 2000 V6 and just have no idea what to do with the hose. Help!
    I dont have a 2k but it should be the same as a 98 v6. Just remove the air silencer (the big black thing that goes inbetween the stock air lid and the throttle body) remove it and throw it away. Then install the new lid and the hose goes from the new lid streight to the throttle body.
      Thanks, I will try that now
        Shoot, how the heck do you get that air silencer off?
          You have to pop off those two plastic pins holding it on. Don't throw it away though. Before you get started though, make sure you have a new air intake hose. I think Whisper Lids come with them. My lid didn't. Had to buy a 4" dia hose from advance auto for 11 bucks.
          <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
            Okay I removed the air silencer with no problems. Now my 2000 says to use a pre-existing hose from my car so do I use the hose that runs from the first lid to the silencer, or the one from the silencer to the TB? Also how do I unclamp those clamps without a flat-head screw? They are really tough.
              Well it took me awhile but i did it! Great new sound, and it feels fairly stronger already. Thanks for the input guys.
