strange exhaust rattle - FirebirdV6.com/CamaroV6.com Message Board
  • strange exhaust rattle
    ok, I have a light "metallic" rattling sound coming from around the passenger side rear fender, but it only occurs under hard acceleration, and always happens within a certain rpm range. When the rpms get past that point and the car shifts into OD, it stops completely. Any ideas?
    2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
    Sounds like a heat shield could be coming loose or some of the exhaust plumbing is vibrating against part of the body or suspension.
      Cat i bet...mine does that and thats exactly where the cat is
        my cat makes the same sound at a certain time under moderate acceleration... thats why im gonna just hollow the ***** out and put it back. no more worries!
        <a href=\"http://www.cardomain.com/memberpage/325081\" target=\"_blank\">1998 Red Firebird M5</a><br />not enough mods
          same thing happend to me right before mine went. you want to go ahead and hollow it out or get a new one before it goes cause it sucks once it finally dies (you cant get up over 30 and it takes forever to get that fast).
            Well that blows....the cat only has like 40K on it....
              Chances are, you have the same problem I do. Your muffler is rubbing your gas tanks heat shield. Easy fix is to just grab some exhaust rubber hangers and jam them between the muffler and heat shield.
              -Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
                ^^^ i agree with him...it comes VERY close to those heat shields...id take a look at that...and hollow out the cat...it delivers a kick @ss sound...and mine is yet to set a code
                  oh...one more thought..i had trouble with mine rattling against the tunnel brace once...might wanna check that out too
                    mine is doing the exact same thing. i figure its the cat heat shield cause i bottomed it out real bad last night and i noticed it just today
                    2000 3.8 A4 Pewter Camaro
