ok, I have a light "metallic" rattling sound coming from around the passenger side rear fender, but it only occurs under hard acceleration, and always happens within a certain rpm range. When the rpms get past that point and the car shifts into OD, it stops completely. Any ideas?
strange exhaust rattle
Sounds like a heat shield could be coming loose or some of the exhaust plumbing is vibrating against part of the body or suspension.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
same thing happend to me right before mine went. you want to go ahead and hollow it out or get a new one before it goes cause it sucks once it finally dies (you cant get up over 30 and it takes forever to get that fast).2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Chances are, you have the same problem I do. Your muffler is rubbing your gas tanks heat shield. Easy fix is to just grab some exhaust rubber hangers and jam them between the muffler and heat shield.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
^^^ i agree with him...it comes VERY close to those heat shields...id take a look at that...and hollow out the cat...it delivers a kick @ss sound...and mine is yet to set a code<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
oh...one more thought..i had trouble with mine rattling against the tunnel brace once...might wanna check that out too<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
mine is doing the exact same thing. i figure its the cat heat shield cause i bottomed it out real bad last night and i noticed it just today
