My borla rusted on in 2 months! - FirebirdV6.com/CamaroV6.com Message Board
  • My borla rusted on in 2 months!
    The right side ajustment where you can put in the different plates has rusted totaly up, I guess that part isnt stainless steal. I only installed it the first week of january.
    I have the smallest open plate in right now, I attempted to take out the bolts yesterday and they are in the worst of places! I put it together when it was on the floor so those two top ones are imposible to get to now.
    WHen I finly got my wrench on it ,I torqued down, the wrench slid off and I sliced my knuckles open (hands taped up in the clawed position) If I ever take another crack and get those bolts out I am changing them for some smaller ones that dont require threading.
    ~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
    WD-40. It will losin those bolts right up. I just changed my plate and had to use the stuff. It really did wonders. I have had my Borla on for about a year now and no rust on that part. So that sounds weird it would rust like that.
    Factory:Camaro 5 speed, Color Pewter, w/ t-tops and Y87 package. <br />Engine: K&N filter w/ Whisper Lid, FRA, Borla adjustable cat-back exhaust. Hurst w/ Short Stick<br />Interior:Oil temp. and Air/Fuel ratio gauges, System.<br />Exterior: Black outs front and back, 18 in. Lenso rims w/ Kumho Supra 275/35ZR18 tires, also limo tint on sides and back.<br />173.2rwhp-----200.5tq
      There are different grades of Stainless Steel. The cheaper ones have other metal mixed in and will eventually rust.
      [ February 23, 2003: Message edited by: aawil ]</p>
        use a product called PB Blaster that stuff makes WD-40 look like water
        97 \'maro 3.8L with magana flow exhaust and K&N air filter
          <blockquote>quote:</font><hr>Originally posted by grndlvl:
          use a product called PB Blaster that stuff makes WD-40 look like water<hr></blockquote>
          agreed! [img]graemlins/thumbsup.gif[/img]
          Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
            I think it is mostly the weld's that rusted but never the less it is in a difficult place.
            While we are on this subject, what is the best plate to have in? I have the smallest open one and it sounds kinda like my boat when it is out of the water :D
              Doesn't Borla have a no rust guarentee? If your exhaust rusts they replace it for free. At least that's what I think their policy is.
