Has anyone removed the Secondary Air Injection System? I think only the 3.4's w/manual trans had it, and I need to take mine off because my pacesetters don't have a spot to connect it. I'd get a bung for it welded in, but if I don't need it for the car to run well, then I'll just take it off. Has anyone at all done this or at least knows what I'm talking about?
Removing AIR System
I would take mine off but I'd probably fail my emissions inspection without it. If you still have the stock intake plastic you just need to block that off. Getting the metal tube off where it wraps around the back side of the motor might be tough. The motor should run just fine without it but if you want to see if it sets off an SES light try unplugging the electrical connector and see what happens.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
It's simple to remove. There is an AIR pump on the front driver's side frame rail. Remove that and all of the plumbing and you're set.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
unless you have a visual inspection you should pass. it only runs the first few mins of start up to heat the cats. it "should" not set a code when removed either1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by HBHRacing:
unless you have a visual inspection you should pass.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...3 days ago
