buying oxygen sensors.. - FirebirdV6.com/CamaroV6.com Message Board
  • buying oxygen sensors..
    hopefully I'm gonna change my O2 sensors this weekend....What do you guys think is the best O2 sensor? I think I'm gonna buy Bosch. At Pep Boys i can get them for $24.99 each, or Advanced for $19.99 each...... I'm not sure if the prices are for different type Bosch sensors or not. Which one should I go for?
    I'm also gonna buy the socket for it, that's $11.00.......duh
    What should I do when removing them? I know I need wd-40 or such to loosen them up first.
    As far as the plug downstream of the sensor, I know that unclips..does the wire on the new sensor just hook into it, or do I have to do some splicing?
    Thanks for the help guys. I just wanna get everything straight before i buy the sensors and put them in.
    As far as removing them, heat them and the manifolds up slightly by running the motor for a minute or two. After this, mine came out easy. I didn't have to spray any penetrating oil. The ones I bought had antiseize already on them so I didn't have to add any and it actually said not to.
    I can't help on the brand choice. I went with AC Delco replacements, same as factory. In case you want to do this GMPartsDirect has them for about 1/2 the price(before shipping) as the dealer.
    Delco PN = AFS-22
    GM PN = 25162753
    [ March 22, 2002: Message edited by: Backfire ]</p>
      Thanks for the info Backfire
      2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
        <blockquote>quote:</font><hr>Originally posted by Cale:
        Thanks for the info Backfire<hr></blockquote>
        I'm supposed to say that Cale.....
          so i guess i have to undo the clip and put the wire up in the socket to start turning it out...is that what i should do with the wire?
          What about the clip? Do i undo the wire from the old sensor that's going into the clip and put the new one right in it, or do i have to splice the wire from the new sensor to an old wire coming out of the clip? Hope this isn't confusing
            Well I got bent over with no lube at Advance Auto Parts, they charged me $60 a piece for new o2's :eek: :mad: Well I wondered why my a$$ hole hurt so bad when I paid them for them [img]graemlins/crybaby.gif[/img] [img]graemlins/thumbsdown.gif[/img]
            97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
              <blockquote>quote:</font><hr>Originally posted by GregWS6'01:
              <hr></blockquote>
              Yes, very easy install. You don't even need to get the O2 wrench. A regular deep well socket will work fine. The wire simply plugs in.
              Josh-
              \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
                Thanks guys.....I'll be tackling that shortly. I may buy the socket, I may not. If i end up buying it, I might resell it on here for someone else that wants it.
                  done...wasn't too bad except trying to find swivel extensions so i could actually get to them. driver side was a sinch......passenger side took a little time...I didn't notice a difference right off the bat.....but i think the car had to adjust to em..Not a noticeable difference but with 105K on the stock ones it was time for some new ones. My passenger side one was burnt black. I might be selling my socket, so if anyone is interested, let me know.
                    I wish I had caught this post earlier. The 3.4's have a one wire O2 sensor...it's a data sending wire only. With a high flow exhaust system, the O2 sensors don't always get hot enough to give a good reading. A few weeks ago, I finally installed two 3-wire O2 sensors (Bosch) that I have had for a while but never installed. I got teh harnesses from GM to hook them in. The difference in the two setups is that the 3-wire is a heated O2 sensor. In this case, the O2 sensor will give a better reading at all times resulting in better engine performance. The O2's are not cheap though...cost around $50 each and the wiring harnesses are about $12 each, but they are not manditory. This mod seems to give better power throughout the rpm range, but I have not dynoed to get a true power change. Throttle response is a lot better and gas mileage is better. If you are in the market for new O2's and have a single wire O2, I would suggest this if you have the money. If nothing else, you will get better has mileage.
                      <blockquote>quote:</font><hr> Well I got bent over with no lube at Advance Auto Parts, they charged me $60 a piece for new o2's Well I wondered why my a$$ hole hurt so bad when I paid them for them <hr></blockquote>
                      98's have 3 O2 sensors on the exhaust, pepboys quoted me
                      79.99 for 1
                      69.99 a piece for the other two.
                      so saving $40 plus tax doesn't sound too bad.
