Back from loudmouth install - FirebirdV6.com/CamaroV6.com Message Board
  • Back from loudmouth install
    And it still is sitting in the trunk :(
    My present set up is as follows:
    Y pipe
    Where the y pipe combines it is 3 inch
    There is a 4 inch section of 3 inch diameter piping
    it then reduces to 2.5 inch
    then 2.5 inch in and out cat
    then the s pipe is 2.5 inch NOT mandrel bent
    the bends are slightly smaller than 2.5 inch
    then the i pipe goes from 2.5 to 3 inch
    then 3 inch edlebrock cat back
    If we tried to do the loudmouth install most likely we would have left the s pipe alone, cut the piping just before the resonator on the new set up and install only a portion of the loudmouth.
    I spoke with my exhaust shop for a while.
    We decided the best way to go is start from scratch.
    The y pipe is 3 inch so I will order a new 3 inch catco high flow cat from summit today and everything from the y pipe back will be brand new.
    The diameter will increase from 2.5 to 3 inch.
    All the bends will now be mandrel bend.
    I have always sworn by 2.5 but it looks like 3 inch will be installed.
    It will be insteresting to see what the difference will be in rwhp, rwtq, et and mph change.
    Wouldn't it be funny if dyno numbers sky rocket??
    I should be hitting the track n/a this weekend.
    The loudmouth kit weighs 26 pounds
    So, I ended up changing tires today
    ET streets are thrown away
    Nitto drag radials are thrown away
    New bf drag radials are mounted on maro 16 x 8 salad shooter rims
    I knocked off 1 pound vs 5 star 16 x 8 pontiac rims
    245 50 radials are mounted on 5 stars and on the bird now
    I'll be ordering et drags and weld rims as soon as the nitrous runs begin.
    I think I am going to install my sparco evo seat now, I'll post results later [img]smile.gif[/img]
    Loudmouth should be installed in the beginning of next week. I'm off mon, tues, and wed.
    Basically as soon as the cat arrives I get the loudmouth installed.
    Same thing happened to me. Thats how I decided to go ahead w/ the 3" HF cat-- when the shop said it would be MUCH easier to install with full 3" pipe everywhere. I think he said he would have had to cut part of the Loudmouth to get it to fit, which i didn't really want. Looking back i'm happy with the decision. :D
    I'm really looking forward to seeing some dyno numbers, comparing this whole 2.5 - 3" thing. :D [img]graemlins/thumbsup.gif[/img]
    -Justin
    2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
      I wanna hear what it sounds like on a 6.
      I had a cutout with 3" piping on my 3.8 and it sounded nice.
      Now I am waiting on an ORYP for my SS and we'll see how that combines with the loudmouth. [img]graemlins/thumbsup.gif[/img]
      *MATT* <p>98 Camaro SS #1767 A4<br />Artic White<br />Not stock...<p>Former car:<br />96 Firebird Y87 A4<br />Bright Red<br />Wasn\'t stock...
        You talk about the salad shooters, have you ever thought of getting some of the metal rims that are behind the hubs? I bet that those might save about 10 lbs.
          <blockquote>quote:</font><hr>Originally posted by naptown:
          You talk about the salad shooters, have you ever thought of getting some of the metal rims that are behind the hubs? I bet that those might save about 10 lbs.<hr></blockquote>
          I'm confused on what you mean?
          You are not talking about the drums are you?
            <blockquote>quote:</font><hr>Originally posted by 12secondv6:
            <hr></blockquote>
            I think he is talking about those old Basic package Camaro wheels with the hub caps on them, or at least they look like hub caps never paid to much attention to them. I think they are a lil heavier than the salad shooters though
            97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
              it's gonna sound awful...but i think you should put some flanges put in between the y-pipe and s-pipe so when you go to the track, you can put a straight 3" pipe in place of the cat. that will allow much more flow, a little less weight, and better times i assume. get an o2 simm while you are at it, that way any false leaks around the flanges won't screw up your o2 readings.
              2000 NBM M6 Camaro Z28<br />323/335
                <blockquote>quote:</font><hr>Originally posted by Only4U:
                it's gonna sound awful...but i think you should put some flanges put in between the y-pipe and s-pipe so when you go to the track, you can put a straight 3" pipe in place of the cat. that will allow much more flow, a little less weight, and better times i assume. get an o2 simm while you are at it, that way any false leaks around the flanges won't screw up your o2 readings.<hr></blockquote>
                Whats a cat [img]tongue.gif[/img] ;)
                  Where do you get a 3'' Hi Flow Cat?
                    Where do you get a 3'' Hi Flow Cat?<hr></blockquote>
                    http://www.camarov6.com/cgi-bin/ulti...&f=25&t=002839
                    Matt
                    Matt
                    1998 Mystic Teal Camaro M5
                      you think it sounds awful?
                        Moving to Intake/Exhaust...
                          Here is more info:
                          http://www.camarov6.com/cgi-bin/ulti...&f=25&t=002938
                          Cat is from summit racing.com
