I got this code recently and don't know what to check or replace. Does anyone know what is it?
What is P0420 TWC System Low Efficiency?
"Catalyst system efficiency below threshold, left bank" - Haynes Repair Manual
something to do with your O2 sensors. do a search, someone had this problem recently. Hope this helps.
[img]graemlins/burnout.gif[/img]~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
Don't know about different brands, not sure if it even makes a difference with something small like this(except quality probably effects life of sensor), BUT from what i've heard, Bosch are very good and have a price to match :D I think last time i checked it was ~$50 for one. :( and we have 4!
Now that i think about it, my car also has over 100K miles on it, and the SES light has been coming and going for a month or two. How did you pull that code, cause i need to find out why mine keeps getting set? It will turn off and on while i'm driving [img]graemlins/dunce.gif[/img] . Off the top of my head i thought it might be my IAT sensor because its been a lil abused.
[ April 20, 2002: Message edited by: Dojo2000 ]</p>~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
I went to get price estimates at PepBoys and Autozone. Two of them say they need to be replaced at 100,000 and it's $60 at PepBoys(don't know brand) and $50 at Autozone for Bosch. These are the two before catalyst. The other two are $80 at Pepboys and $75 at Autozone.
I can't believe they are so expensive. Total would be $250-$280 if I wanted to replace all 4. I might just replace the two that need to be replaced at 100,000.
I had Keith autotap the code for me so that's how I know. It only showed up once though. I reset the PCM and haven't seen the code yet. I guess it's probably an early warning.
I would say the difference in the brand would be a difference in quality, as was mentioned before.
Dojo, Autozone has scanners that you can borrow, and use in their parking lot, and you can run it there. If you have a 98+ car, it plugs in by your right knee in the driver's seat.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
Ok so which sensor do I need to buy?
AC Delco part # GM part # Description
AFS-17P 8990793 three wire, 4 hole connector
AFS-40 25108302 four wire, 4 hole connector, redundant signal ground
AFS-41 25108814 three wire, 3 hole connector
AFS-45 25132086 four wire, 4 hole connector, redundant signal ground
AFS-49 25132271 three wire, 3 hole connector
AFS-60 25132529 four wire, 4 hole connector, redundant signal ground
AFS-48 25132169 three wire, 4 hole connector
AFS-63 25132674 three wire, 4 hole connector
AFS-62 25132616 four wire, 4 hole connector, redundant signal ground
AFS-65 25132819 four wire, 4 hole connector, redundant signal ground
AFS-66 25132789 three wire, 3 hole connector
AFS-72 25133358 four wire, 4 hole connector, redundant signal ground
AFS-75 25312184 four wire, ???
I have to buy them in pairs right?
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...3 days ago
