I have now checked out three different places in my attempts to find a 3" s-pipe. Each place quoted me at $400 to do it. Thats the biggest rip off ever!!. Can you buy a 3" s-pipe anywhere? I'm so fed up with this, its the only part holding me back from my 3' cat back system.
S-Pipe blues....
You can get two 90 degree mandrel bends from JC Whitney for less than 30 bucks. Some members get 45 degree bends. You can also do like I did and get a 3inch ipipe for 93-95 z28 from summit racing. Cost under 100 bucks. Part numbers 42273 and 45593. You need both parts. I didn't need an s-pipe. Muffler shop made it work by adding two 3-5 inch pipes to my total setup. Hope this helps.
[ April 22, 2002: Message edited by: AMinor65 ]</p><b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
<blockquote>quote:</font><hr>Originally posted by nofear_102:
I have now checked out three different places in my attempts to find a 3" s-pipe. Each place quoted me at $400 to do it. Thats the biggest rip off ever!!. Can you buy a 3" s-pipe anywhere? I'm so fed up with this, its the only part holding me back from my 3' cat back system.<hr></blockquote>Click Here. You can order two 45 degree pipes for your S pipe. I had the 90 degree pipes at first, but thanx to slacker, I found outthe 45 degree pipes will work and flow better.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
Just to double check, you ordered 2 of these?
"45 Degree Mandrel-Bent Aluminized Tubing, (A/B)=7", (C)=3", ID=1-3/8", OD=1-1/2" "
!<hr></blockquote>
That's correct. You need 2 of em to make the S pipe, but not that part# you have quoted. Click my S Pipe link in my sig for the correct one.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
That is a far better solution. [img]graemlins/burnout.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
hey dominic what size pipe is that ? it doesn't say in the discription.98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
<blockquote>quote:</font><hr>Originally posted by Dominic:
http://www.slponline.com/view_product.asp?PARTNUMBER=30045&SHOWIMAGE=On&SHO WEMAIL=Off
That is a far better solution. [img]graemlins/burnout.gif[/img] <hr></blockquote>
That pipe is made for something else.
[img]graemlins/bs.gif[/img]<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
Easy now... Don't make me bring out Toto
Down boy!!! [img]graemlins/toto.gif[/img]Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
http://seppo.hopto.org/
The SLP pipe is a 3" S-Pipe and links up perfectly with any *normal* 3" I pipe and 3" cat.
Hell, Im getting it.2002 5-spd NBM Camaro
Thanks for the 411 guys. I think I'm going with the SLP S Pipe also. [img]graemlins/burnout.gif[/img]1997 Red M5 3.8, 3.23 Gears<br /><b>Performance Mods:</b><br />SLP CAI, RKSport Headers, 3\" Catco Cat, 3\" Cut-Out, SLP S-Pipe, 3\"I-Pipe & over-axle (Custom from shop), Hooker Headers Muffler, Hooker Header Tips.<br /><a href=\"http://members.cardomain.com/redrider45\" target=\"_blank\"><b>My Ride</b></a>
