header install - FirebirdV6.com/CamaroV6.com Message Board
header install
  • header install
    to everyone that has headers, did u bolt them or weld them? I plan on having this car till it dies, and i dont plan to replace the headers again, so should i just go ahead and weld them if possible? no leaks or loose bolts.....
    Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
    lol, no. i would not by any means weld them. just bolt them up like your suppose to [img]smile.gif[/img]
    if you do it right. you wont have to worry about leaks.
    2000 3.8 A4 Pewter Camaro
      is there anything u recommend as to what kind of gasket to use, the one they send me or get a better one, or any different kind of bolts? i dont like the thought of leakage and loose bolts.... :(
        the gaskets they send and bolts should work if you do it right [img]smile.gif[/img] its not that bad
        about the bolts, you'll never lose them if you tighten them down every couple days until the stay tight. dont forget the y-pipe bolts too
        no problem [img]smile.gif[/img]
