The Motorvator Throttle Body Spacer - FirebirdV6.com/CamaroV6.com Message Board
  • The Motorvator Throttle Body Spacer
    Does any one have any insight on this product?
    I found it at rpmoutlet.com.
    It says, due to the "air vortex" it can create:
    Quicker Acceleration
    Power gain in the lower rpm range
    Increased fuel mileage
    Increased airflow
    Will not affect emissions (C.A.R.B. certified)
    complete with all gaskets and hardware
    Red \'99 3.8<br />Induction: SLP Cold Air Intake, K&N Air Filter, Whisper Lid<br />Ignition: Taylor Spiro-Pro Wires, Bosch Platinum 2 Plugs<br />Suspension: Power Slot Rotors, Hawk HPS Pads, Mille Miglia MM11-2 18x9, Goodyear Eagle F1 GS-D3 245/40-18
    We have a board member who custom makes these for our cars... I think it would be cool if you supported and gave your money to him rather than someone else.. ;)
    Do a search on the Dee Throttle Body Spacer and you'll find info on it, and how to install/order it.
    Probably cheaper too.
    Good luck [img]graemlins/thumbsup.gif[/img]
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
      Just an FYI that Dee is no longer producing these for individual sale. If someone were to get a GP together, he may consider it.
        Oh, well if that's true, my mistake...sorry for misleading :(
          zzperformance sells them.
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            I want one, and I support the guy... whats his name -=) but yeah GP is required. so yeah Im interested if you are. anyone else? and yeah, the Idea behind a TB spacer is it increases area for air, so more sits in the TB before entering the engnie. so its supposed to be good. but like I just want it cause I heard it makes a sort of air swooshing sound. That + SLP Swoosh would be awesome, with MY high flowcat and the SLP and the Cutout open my car sounds Turboed ( GIVE ME SWOSH OR GIVE ME DEATH. ) ... so yeah. I want one.
            97 Special Edition Bird , Short bus stlye special
              O but Im a loser with a 97 =/ Wahts the diff in the throttle body.
                <blockquote>quote:</font><hr>Originally posted by Dominic:
                zzperformance sells them.<hr></blockquote>
                If it's made to fit the GPGT or GTP, it won't fit our cars. Throttle bodies are a little different.
                The spacer pictured at zzperformance will not fit.
                <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
