I'm assuming you're talking about the cat. converter. If so, don't buy it. You can get a catco highflow cat from summit for around 50-60bucks depending on the inlet-outlet sizes. Spark plug wise, get Bosch, NGK, or AC Delco.
If you want, you can look into buying a Magnaflow or Dynomax cat. But I would just buy a Catco cat from SummitRacing.com. You can also look into Mor-Flow cats if you want to explore another option.
Spark plug wires: Taylor has good economical wires, you can find them on ThunderRacing.com. Otherwise I'd probably look into getting some ACCEL or maybe MSD wires.
EDIT: Oh, right, the plugs themselves. Get either the stock AC Delco Platinums, or else the AC Delco Rapidfire platinums. (PN 14).
<blockquote>quote:</font><hr>Originally posted by GregWS6'01: Catco makes high-flow and they make regular....I bought mine from JC Whitney<hr></blockquote>
J.C. whittney also sells a nice stainless steel high flow "headerman" cat for around $100.
<a href=\"http://groups.msn.com/WhoisNightRider/bluethunder.msnw\" target=\"_blank\">2002 Electron Blue Corvette Coupe</a><br /><i>13.083@108.23</i><br /><br /><a href=\"http://groups.msn.com/WhoisNightRider/redfire.msnw\" target=\"_blank\">2002 Metallic Red Grandprix GTP</a> <b>SOLD</b><br /><i>14.49@94.42 (Bone stock)</i><br /><br />2002 Black Convertible Camaro Z28<br /><i>times comming real soon!</i>
