Ive been wanting to dual my exhaust out for a while now, dualing it at the muffler of course. What would happen if i removed my cat? Ive always heard if a cat is going bad, it will have a bad smell, if i remove my cat, will i have the bad smell all the time? Will i free up any power from removing the cat? Will i get a diffrent sound with the cat removed, i DONT WANT a loud muffler. Thanks
removing cat question
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
Re: removing cat question
it will be very loud and quite raspy if you remove the cat. you may free up 1-3hp though, but personally, i couldnt justify it for the racket you will make. go with a 3''in inlet and 3'' outlet high flow cat. A high flow cat will make it louder and more mellow sounding, and you will still pick up 1-3hp.Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
First of all, if you remove the cat, there will be no bad smell. The smell comes from sulfuric compounds escaping due to the cat failing.
It also shouldn't change the noise level much, especially if you have a stock muffler. I know that when I lost the insides out of my cat, the volume didn't change considerably. The exhaust might become more raspy, though, because you decrease your back pressure by removing the cat.
Like Harrison said, you'll gain a couple hp, but nothing much.
The best advice I can give is:
If you have to worry about passing emissions, either get a new cat, or a high flow cat.
If you don't have to worry, get rid of it.UAH FSAE<br />Chief Engineer<br /> <a href=\"http://chargermotorsports.com\" target=\"_blank\">http://chargermotorsports.com</a> <br /> <a href=\"http://members.cardomain.com/camaronat\" target=\"_blank\">http://members.cardomain.com/camaronat</a>
i ditched my cat a couple months ago and it sounds fine....noticably louder w/more volume....doesnt sound bad at all......sounds exactly like a v8 at idle and when rollin through parkin lots and such.....not much of a ricey tone at all up top either.\"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
