Ok I bought a pair of copper gaskets for the collector plate, (the part that conects the cat to the y pipe for the headers).
The gaskets have a triangle grove on one side which makes the other side hump out. Ok my qusetion is how do I put these on?? Both going the same way or both groves towards the inside which make the hump side stick outwards?
