SLP CAI upgrade - FirebirdV6.com/CamaroV6.com Message Board
SLP CAI upgrade
  • SLP CAI upgrade
    Is it worth to go on SLP CAI upgrade, specially those of you that have it already installed?
    http://fasttoys.net/shop/product_inf...products_id=42
    If so please share some pictures to see how it looks installed.
    Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
    Re: SLP CAI upgrade
    I have the scoop extender on mine, I guess it just helps direct air to the cold air duct a little better, nothing major.
    If you're looking to upgrade go to lmperformance.com and get the austin scoop add-on.:poke:
    http://www.lmperformance.com/3476/13.html
    Camaro V6 - 14.3 @ 96mph
    Camaro SS - cam/boltons/m6/tune
    http://www.crfhq.com
      Re: SLP CAI upgrade
      should have gotten the Austin Super Sucker Ram-air in the first place
      2000 3.8 A4 Pewter Camaro
        Re: SLP CAI upgrade
        Well, this is what the description of this item says:
        "SSRA Scoop Addon for Whisper, FTRAs, and SLP's Cold Air kit as well."
        I've been thinking to make an add-on by myself with two openings in the middle to connect two A/C unit pipes coming from the front grill. This would not interfere with the main opening where the air gets in. Have any of you done something like this before?
          Re: SLP CAI upgrade
          i got the level 2 Austin SSRA.....it's awesome...throttle response is so much better...worth every penny....
          here's my thread about it... http://forum.camarov6.com/showthread.php?t=65208
          09 Nissan 370Z MB M6 Sports Package
          www.the370z.com
            Re: SLP CAI upgrade
            Yeah... but theres like an air slit "hole" to where it connects to the cold air duck, and air can leak from there, reducing the whole supercharging effect.... any clues on that?
            And kala, not sure if your kit came with the rubber gasket or not? it blocks off the old part where air used to suck from, didin't see it in the pic just making sure you have it on..
              Re: SLP CAI upgrade
              it does have the rubber gasket. its not so much about getting boost but getting to cooler air from the front of the car into your intake instead of the engine bay. there really isnt going to be much of an issue with that hole
                Re: SLP CAI upgrade
                [QUOTE=airattack111]Yeah... but theres like an air slit "hole" to where it connects to the cold air duck, and air can leak from there, reducing the whole supercharging effect.... any clues on that?
                A piece of plastic can be trimmed to the form of that hole. Silicone may be used to attach it.
                  Re: SLP CAI upgrade
                  is it hard to install the addon and does it come with everything you need?
                  <a href=\"http://www.cardomain.com/ride/2151539/1\" target=\"_blank\">http://www.cardomain.com/ride/2151539/1</a>
                    Re: SLP CAI upgrade
                    Well my fastoys one does the same thing, but sucks it up straight from the airdam instead, basically just as cold...
                    The the austin has to have some kind of better ram or something to be worth it..
